red light on hondata po6 ecu
Posted: Mon Mar 31, 2008 8:53 pm
When I plug the USB in it says online and makes the noise. the color of the light on the ecu is red. I have tried reinstalling the software and drivers. When I update the usb drivers it comes up as usb drivers updated and when i test usb it comes up as usb drivers installed correctly. However when I go to datalog IAT and ECT both change to 32 degrees in one po6 302 degrees in another po6 regardless of what tempature it really is and the rest of the values stay at zero. And when you go to upload it just does nothing. I have tried other usb cables and they do not work. And my cable i have used on other devices and they worked properly. I have also tried 2 different laptops. i can send detailed pics of my socketing job also since that seems to be the problem most of the time. the first one i thought that was the problem but this one is doing basically the same thing so i dunno
Back to top
Back to top
