ok here is my situation, I drive an 06 SI coupe. I have been reflashed for about 4 months now and it was done through clubrsx.com. My problem now is that I have a greddy turbo kit in the garage awaiting install, and for now (until a kpro equivalent comes out for our platform) I have to use the emanage ultimate to "tune". The problem is that the emanage will not work with the reflash, please correct me if im wrong. Simple solution right? wrong say I swap ECU's with someone else with an 06, I first have to pay $200 for both cars to be rekeyed which i think is redonkulous lol. So i call Hondata the other day to ask if they could flash it back to stock the gentleman I talked to said yes you pay x amount of money yadda yadda. I then proceded to ask if i will still be eligible for a discount on our kpro equivalent when/if it comes out and he tells me no i will not be that i will have to pay full price.
I then ask if they keep on file all serial numbers so they could know i have paid them and I wondered why I would not be eligible for the $500 upgrade cost since i have paid them over $700 (assuming I pay to get it reflashed to stock by them). He didnt explain and was basically like your screwed. I dont really understand, from my past experience with this company they have seemed more than fair, but i have to say this is not quite right... anyways / hondata rant
My problem lies with not being able to install my kit, is it possible (if my tuner knows what he is doing) to run the reflash and emanage together? Its a shame im even asking this, but my other option is throwing away nearly $700 because they will give me no credit.
Please Help 8thgen member in need!
-Josh
Reflash and future upgrade + Turbo = FAIL!
then I might ask has Hondata not stated before that the Kseries reflash should not be used in conjunction with the emanage ultimate for the greddy kit on the 06+ SI? or is this just hear-say?
Your saying if my tuner has patience enough and can retard timing under boost properly it will work fine?
also is it even possible that the reflash will try and fight its way back into control and advance timing and cause detonation?
anyone?!.... we are trying to get started on this install. It has been said that the reflash hasnt been tested with FI applications, SC, turbo ect. Once said it should be used with emanage ultimate, now its stated that its ok. Can some1 please follow up on here preferably Doug, i do not want my car to pull timing because im running emanage ultimate and the reflash.
http://www.hondata.net/forum/viewtopic.php?t=5244
http://www.hondata.net/forum/viewtopic.php?t=6346
http://www.hondata.net/forum/viewtopic.php?t=5343
http://www.hondata.net/reflash_06_civicsi.html
http://www.hondata.net/reflash_faq.html
please please please doug... give me an answer that way we can go ahead and start tonight. Its 8:00 pm here... please HELP Doug
civicn33b wrote:anyone?!.... we are trying to get started on this install. It has been said that the reflash hasnt been tested with FI applications, SC, turbo ect. Once said it should be used with emanage ultimate, now its stated that its ok. Can some1 please follow up on here preferably Doug, i do not want my car to pull timing because im running emanage ultimate and the reflash.
