- K&N Typhoon Ram air intake
Megan Racing Test Pipe
Skunk 2 Cat-back exhaust
and 440 injectors (left over from turbo)
If not, would it be best to swap out the injectors (with stock injectors) and run the base map?
Ill check back here as im looking around for alternate sources for this answer, but i can also be reached at scolas.ffxi@gmail.com
Thanks in advance!
Jeff (scolas)
-2005 SSM Civic Si-[/list]
