07 Si CT-Engineering Flash running lean
HONDACARE
Post by HONDACARE »
I have the flash for the CT-engineering supercharger on my 07 si and it is running 13:1 afr. I have rechecked all fuel mods and everything is right. Help please!
Can you post the dyno chart showing this? Where was wideband reading taken from?
HONDACARE
Post by HONDACARE »
Reading was taken from a tailpipe sniffer. I only have the file on pdf so I here is a link to it:
http://www.8thcivic.com/forums/forced-i ... n-s-c.html
HONDACARE
Post by HONDACARE »
I installed a Wideband A/F gauge yesterday. 1-2 richen up to 12.6-12.1 in the upper rpms, but 3rd is still lean (13.0) untill 7K rpms. is it possible to have more fuel added to my flash?
Modifications?
HONDACARE
Post by HONDACARE »
Mods are:
Ct Supercharger
Injen CAI
DC Racheader with 3"collector and flex
3" exhaust
please help, the Wideband is reading over 12.6 from 6K on
There are no changes that can be made to the reflash. The reflash is designed for a stock car with the supercharger added. Any other changes you make may cuase the car to run rich or lean and you do so at your own risk.
HONDACARE
Post by HONDACARE »
so why does ct-engineering state on their site that:
The addition of Intake, Headers, and Cat-Back Exhaust is Highly Recommended
Try putting your stock intake and airbox back on and see what effect that has. The MAF is very sensative to changes in diameter and shape.
