AEM wideband calibration
Posted: Thu Mar 20, 2008 12:23 pm
by slowerthanu
hey how do i go about getting the aem wideband to communicate with the s300 for data logging? stock 02 setting or analog...and if the analog settings, what calibration do i do?
Posted: Fri Mar 21, 2008 10:15 am
We dont' recommend the use of the AEM wideband, becuase it has only one output. IF you want to be able to datalog the wideband signal into the ecu, and still run closed loop, you must use your stock o2 sensor for closedloop and input the wideband signal into the ELD pin of the ecu.
We recommend the PLX Devices widebands.
