Has anybody with KPRO has had this happen to them before??
Axix23
Post by Axix23 »
Has anybody with KPRO ever had: when you turn your key to ign II, the cel stays on along with the immbol flashing and your car isn't able to crank. But after you take your key out and turn your key back to ign II, the cel is gone along with the immboli light and able to crank up???
BTW, my immbol has been reprogrammed to match my new kpro ecu.. And I do have it enabled in my KAL... And also, at ign II, when the cel comes on along with the immbol flashing, i tried to pulled a code with my labtop and came up with nothing...
This usually happends every 2 weeks or sometimes every month or so...
Axix23
Post by Axix23 »
cleaned my key with alcohol wipes every few days and it took care of those problem.. another thing is to leave your key in the ignition for a few seconds before turning the car on... there was a Acura RL recall out for this same issue about the immbol sometimes not reading the key properly at times... There was a slight delay of signal at times in the RL's immbol...
Axix23
Post by Axix23 »
BTW, I talked to a few other people with Kpro, and this same thing has happened to them, they usually just turn the key and take it out and out the key back in and starts up with no problem..
