Boost control kit
RickyLee53
Boost control kit
Post by RickyLee53 »
Apart from the solenoid what else do i need to control boost? What does the solenoid connect to? I.e. what wires on my ECU?
Do i need to do anything else to the board?
The ecu must be modified with the boost control components. You can have any Hondata dealer do this for you. In Smanager fo the Help, Contents and search for Boost control. Everything you need to know can be found there.
RickyLee53
Spunkster wrote:The ecu must be modified with the boost control components. You can have any Hondata dealer do this for you. In Smanager fo the Help, Contents and search for Boost control. Everything you need to know can be found there.
Never noticed that, thanks.
Doesn't look 2 hard to do, i don't have a dealer near me i'm afraid. I'm in the UK.
Whats the part's i need, i know the resistors, but what diode and transistors do i need?
You should contact CPL, they should be able to assist you with this.
RickyLee53
Spunkster wrote:You should contact CPL, they should be able to assist you with this.
Paid over the odds but just bought from them. Just need a solenoid now.
