3-Bar map sensor
Joelspy70
3-Bar map sensor
Post by Joelspy70 »
Just finished installing my new SVE 3 bar map sensor. It looks similar to the GM or MSD map sensors. The instructions say something about the voltage settings being 1.65v. After messing around with the scalar and offset the car starts fine but the map sensors values in kpro manager stay the same. I am running the latest version of kpro manager. I have no clue how to figure out the formula that is in the help files. If anyone could help be out that would be greatly appreciated.
Joel
03 RSX-S
Peakboost Turbo Kit, Full 3" Turbo back Exhaust, RC 750cc Injectors, NGK-BKR8EIX, Full Race Vaccum Block, Odyssey PC680MJ Battery, Innovative Mounts, Valve cover engine ground.
Kpro Version: 1.2.8
Axix23
Post by Axix23 »
wait for the new hondata 4-bar map sensor to come out, but until then, plug your factory map sensor in and make hot boost cut @ 10.5 psi for now until you get a better map sensor...
