K-Pro o2 Oxygen Sensor options
Posted: Thu Mar 06, 2008 11:48 am
by rufus
I've researched as much as I could on options for o2 sensors. I've read anywhere from "02-04 RSX ONLY" to "match the o2 to the ECU" to "all 02-04 use the same o2" to "the 05 si works". Some of that even came from Hondata admin.
I'm currently running K-Pro on a 2003 Civic D17a2. The ECU is a 2002 CRV 5 speed. The part numbers from the CRV and 05 Civic Si are all different, as well as the Acura one as well. I could obviously go pick up the well known 02-04 RSX primary but I'd really like to clear this up for other d17 people that might end up using the same ECU as I am. Here are the options:
02-04 RSX
02-04 CRV
05 SI
Are all of these viable options? The cost is really the same across the board but this might help when one sensor isn't immediately available.
Posted: Thu Mar 06, 2008 12:55 pm
same sensors, different part numbers, different wire lengths
Posted: Thu Mar 06, 2008 3:11 pm
by rufus
Ah just saw this too:
The Civic HX and all 2004-2005 Civics use a wideband 02 sensor compatible with the K-Pro
Posted: Sun Mar 09, 2008 8:24 am
by rsxmachine
Denso # 234-9005 is a direct replacement, shop around you can get it for under $175 shipped
