SManager V1.3.4
SManager V1.3.4
SManager V.1.3.4 is available for download. The main change is boost by gear and rpm - this also effectively can function as boost by speed, since rpm, speed and gear are interrelated.
SManagerV1-3-4.exe
Changes:
? Firmware version 1.04
? Added boost control by rpm and gear.
? Added 'Adjust' to parameter tables.
? Added proportional table tracing.
Post by 2 0 3 »
Cant wait to try out the new boost control!!
693hp 2.0L 40R tuned with S300!!
10.37 @ 143 on kinda low boost =P
turbotypeR
Post by turbotypeR »
thank you! you guys rock!
92 civic Si
best et:9.43best mph:164
91accordexr33
Post by 91accordexr33 »
I love the boost by gear, been using it for about 2 months now. Held solid on the dyno...
1st 6psi, 2nd 12psi, and 3rd 18psi
Using the AEM Boost sensor, works great.
planetspeed
Post by planetspeed »
Just curious how does the ecu know what gear the car is in?thanks..
Tchleung
Post by Tchleung »
RPM, Speed, and the Gear Ratio Values.
keow
Post by keow »
i try to use gear select ratio. bot it's not working. thanks
keow wrote:i try to use gear select ratio. bot it's not working. thanks
Noted to be fixed
krweby
Post by krweby »
Information shows that I have firmware ver 1.03 but will not let me upgrade to 1.04.
Close Smanager, reopen it, go to File, New and select one of the calibrations from the list and pload it (the one you choose does not matter). When you do this it should update the firmware. When done, upload your calibration.
krweby
Post by krweby »
Spunkster wrote:Close Smanager, reopen it, go to File, New and select one of the calibrations from the list and pload it (the one you choose does not matter). When you do this it should update the firmware. When done, upload your calibration.
Thanks. I'll give this a try when I get home tonight. I'll let you know.
krweby
Post by krweby »
That didn't work. The update for the firmware is grayed out also.
krweby
Post by krweby »
Ok so I got it to work. But I had to use my work laptop to do it. My laptop is running Vista (Everything was working except for being able to update the firmware.) so it might have something to do with it. My work laptop is running XP-pro. Just thought I would let you know.
I really hate Vista I'm thinking of going back to XP-pro or running VMWare so I can run my old programs that don't work under Vista.
Shmaa
Post by Shmaa »
Whats the status on the expanded lambda conversion table?
Shmaa wrote:Whats the status on the expanded lambda conversion table?
Have you tried the new version?
