Ok guys what to do ?
The engine comes with 2 o2 sensor A and B and like we all know you can't jump them together or reverse the wires.
How do I wire up my turbo exhaust manifold with 2 oxygen sensors ?
What are my options ?
-2 o2 sensors in the down pipe ?
-upgrade to a OBD1 ecu with one sensor ?
I can't run closed loop operation.
Any input would be great......
thanks guys
Cam
Turbo JDM B16A with obd0 pr3
OBD 1
The only real solution is to make the switch to OBD 1, you'll be glad you did.
QUICKSILVER RACING
- Contact:
Thanks again guys..........
But the BIG PROBLEM HERE IS!!!!!!!!!!!
HONDATA SOLD ME THE 4B ON THE PR3
And it doesn't even work correctly
So now after spending 800-900 usd I have to get another ECU, obd0-obd1 adapter, different distributor, and then the hondata modification
thanks da693 but the problem isn't how to put a second o2 sensor into the down pipe. Its that pr3 has 1 o2 sensor for 2 cylinders
obd1
You can put the stage 4 you have now on a OBD 1 ecu it's not that hard to do. Get the OBD 1 plugs from a junk yard and a junk OBD 0 ecu and make the harness yourself.
Jeff_Atwood
You can keep using the PR3, but you'll have to run open loop.
Not a big issue if you have the time and tools to tune properly.
I have done it, passed CT emmisions.
You'll need a base map that is set up for open loop as you
cannot 'switch' it in RomEditor.
Procedure:
Export your fuel and ignition tables to a file.
Open the 'open loop' base file and import your tables
Save-As another chip file.
Burn rom with new file.
No More O2 sensor issues, you don't have to run with any if you choose.
Disclaimer: You are on your own as far as your local emmisions laws.
I can send you this base map if you can't get it from Hondata, where
I got it.
Jeffrey_atwood@hotmail.com
Jeffrey Atwood
Hondata Tuner - Connecticut
Procedure:
I got it.
Jeffrey Atwood
jeff where are you in CT?? a friend of mine is in bristol and is looking for a knowledgeable tuner!?
www.hondaswap.com
94 del sol
94 del sol
