Question regarding Editing all tables
TLtypes
Post by TLtypes »
So I am taking the RSX out to the track next friday, I already know I am going to get in about 3 runs if that, so I will not be messing with fuel/ignition for different cam angle tables.
I want to leave the cam angle map alone as it is in the basemap and just dial in the fuel as best as I can during the limited amount of runs and play a bit with spark advance. Will I be able to get the fuel mixture if I were to use the Edit all the tables option for low and high cam, instead of dialing in each individual cam angle. Is it possible?
magnEsium
Re: Question regarding Editing all tables
Post by magnEsium »
TLtypes wrote:So I am taking the RSX out to the track next friday, I already know I am going to get in about 3 runs if that, so I will not be messing with fuel/ignition for different cam angle tables.
Sure can, just use the Lambda Overlay for fuel. I suggest you find some nice long, deserted roads before you go to the track and do some 3rd gear pulls whilst tuning A/F via Lambda Overlay, should be no longer than 4 or 5 datalog sessions, then if you feel comfortable advancing knock without a dyno, now would be the time to do it, of course if you get knock, then you'd be removing ignition.
magnEsium Tuning
http://www.magtuning.com
