So I have version 1.3.2, have yet to upgrade to 1.3.3 as I'm a bit weiry. Ever since upgrading from 1.3.0 to 1.3.2, all my af's were leaner in boost by over a whole 1.0. After retuning it, it wasn't a big issue, I did notice one thing when I was idling and turning on the datalog via switch hooked to B5 A/C switch and EVERYTIME I would turn it on, it would bump my idle from my 950ish to 1400 or so. Whenevr I turned it off, it would go back down to where it was. When it is idling up during datalog mode, I an rev it and the idle drops back to 1400-1500. Anyone else have this problem? Here are two logs, you can see at the beginning my idle is around 950 on both but then right away it jumps to 1400-1500 and mainains until I cut the datalog off.
EDIT: I do rememeber on the V 1.3.0 when I would hit datalog at idle, the idle would slight budge maybe 50rpm but would always return.
Problems When Datalogging, V 1.3.2
