Hondata Boost Solenoid
WPB EP3
Post by WPB EP3 »
I was under the impression I could configure my GM unit to operate normally closed..
Is your solenoid the only one that actually works this way? If not, whats makes your solenoid unique?
Thank you
modified EP3 cn kit/K24a1/K-Pro
Yes, if you swap over the little foam filter on the GM solenoid. However, in my initial testing I found the solenoid did not control boost very well when configured this way.
