High Gear Conservative Map.
Posted: Tue Feb 26, 2008 1:03 pm
by pyro6314
Just wondering if it would be possible or feasable to implement a feature that allowed a fuel economic map to be used when you shift into 6th gear. This would be a nice fix for nasty fuel consumption, especially for those of us that drive almost an hour every morning to get to work.
1st-5th equals a very agressive and fuel hungry map. 6th is a weak but fuel saving map for high way cruising.
Just a thought, leave comments.
Posted: Fri Feb 29, 2008 6:05 pm
by kommon_sense
No need for a map like that. The best way to do it would be to tune the low vacuum columns (1-4/5) for economy. That will do more for overall fuel economy than a 6th gear map alone. If you have the A/F set properly in those areas, then you can just set the cam angles for economy.
