My K20A2 Need Help HONDATA!
Vasco
Post by Vasco »
Dear HONDATA,
I have a 2004 euro civic type r
I need desesperatly a software to this engine mods!
Can you get me one please?!!!!
this is my e-mail: vaoliveira@remax.pt
-K-Pro ECU
-injen cai
-rbc inlet manifold
-TODA exhaust manifold + direct inox b-pipe + super sprint oval muffler
-Schrick cams, similar to TODA A3 with 13mm open valve
-TODA valve springs
-TODA Timing Chain Tensioner
-TODA Metal Head Gasket plus a litle scratch motor head
Thanking you in advance and looking forward to hearing from you, my best regards.
Vasco
Sorry, we don't have a calibration for that. You will need to get this tuned on the dyno. Start with the one tuned for ITR cams for a PRA ecu.
Vasco
Post by Vasco »
Spunkster wrote:Sorry, we don't have a calibration for that. You will need to get this tuned on the dyno. Start with the one tuned for ITR cams for a PRA ecu.
Pra ECU? What?s that?
Vasco
Post by Vasco »
What is the best place to tune my ecu? I am in Portugal. But i can go Spain or somewhere else....
PRA is the type of ecu a European Civic Type R uses. You can see a complete list of our deaelrs at http://www.hondata.com/dealers.html
Vasco
Post by Vasco »
With this:
"-TODA Metal Head Gasket plus a little scratch motor head"
1 -The engine compression is probably too high. What precautions should i have tuning k-pro?
2 -If the ratio air/fuel is set with the right values on dino, the compression i have doesn?t matter, right?
3 -With a high engine compression the risk of detonation at high rpm (9000rpm) at 6th gear is higher? But this doesn?t matter if my previous question is true, right?
Hondata, these are the questions that concern me the most.
Best regards,
Vasco
