How to disable the O2 sensor for racing header on KPro?
Posted: Sun Feb 10, 2008 2:06 am
by Toto
I will be installing a racing header and I heard KPro could disable the O2 sensor to remove the CEL. Do I just check the "Disbale P0134 (O2 sensor response)" box to eliminate the CEL? Will I still need a defouler with the KPro to prevent the CEL? Thanks!
Posted: Mon Feb 11, 2008 10:53 am
You'll need to disable obd2, not the primary sensor.
Posted: Mon Feb 11, 2008 1:31 pm
by Toto
Is it better to use a defouler and leave the OBDII on? What is the catch of disabling the OBDII? Thanks!
Posted: Mon Feb 11, 2008 2:27 pm
IT would be better to just disable OBD2, there is no catch.
Posted: Tue Feb 12, 2008 12:36 am
by Toto
Does OBDII scanning also check sensors' malfunctions? But I am not sure which sensors it checks. If it is disabled, how can we tell if all the sensors are functioning poperly? What happen if one of the sensors malfunction with no CEL due to the ODBII disabling? Would this hurt the engine if we keep driving and rev high? Thanks!
Posted: Tue Feb 12, 2008 10:33 am
Disabling OBD2 only disables emissions related errors.
Posted: Fri Feb 29, 2008 8:11 am
by BlownSi05
I have been running for 43k miles with OBDII disabled and have never had a problem. I had the car tuned with it off and have never looked back. you will not damage anything or miss out on any important sensors or warnings.
