Is It a bug ?
Posted: Sat Jan 26, 2008 7:37 am
by JITU
Hi,
I am running S300 ver 1.3.1.0 on my JDM P30 ECM, I have hooked up my PLX Wideband analog o/p to D10 ELd to measure wideband AFR (ELD Disabled), under Voltage/Lambda Conversion in parameters. I have set it up as Voltage=0.00 > 10.00 AFR & Voltage = 5.00 > 20.00 AFR. Now if i go to main menu under Options> Settings> Units > Lambda Unit & select Lambda instead of A/F Ratio this funny thing happens, under parameters the voltage/lambda conversion the 0.00V now reads as 1.47 lambda & 5.00V reads as 0.74 Lamda. Should it not be the other way round? A richer mixture should have lower lambda value. its bit confusing sometimes. can you guys have a look.
Or am i wrong somewhere? I would be very thankful if you guys let me know at the earliest.
jitu
Posted: Mon Jan 28, 2008 10:34 am
Double click on AF in the sensors list and change it to read AF instead of Lambda.
