Can't adjust TPS above 84%
Posted: Fri Jan 18, 2008 1:24 pm
by SOHC_STUDENT
my TPS reads 1v to 6v
I'm using the Read function within Scale TPS to try and set the 0 - 100% throttle.
With my foot off the pedal I press Read next to Minimum Reading and it sets the value to -0.22. Then I WOT and press Read next to Maximum Reading and it sets the value to 60.
Testing the throttle with these settings produces 0 - 84% throttle.
I cannot set the Maximum Reading below 60.
What am I doing wrong?
Posted: Fri Jan 18, 2008 2:32 pm
by mike93hatch
adjust the TPS on the throttlebody.
Posted: Fri Jan 18, 2008 4:11 pm
You may also have to adjust your throttle cable if it is not fully opening the throttle plate.
Posted: Sun Mar 02, 2008 9:44 am
by SOHC_STUDENT
Thanks for the reply - I still can't get the TPS to scale higher than 84%
I can hear the throttle plate click all the way open and close. This is the same throttle setup that read 0 - 100% TPS in the last version of Smanager. This problem arose after updating to 1.3.1
If I could adjust the "Maximum Reading" below 60 that would scale it closer to 100%.
Posted: Mon Mar 03, 2008 10:47 am
The problem is not the software, it is your sensor. It either needs to be manual adjusted or replaced.
