Wideband with non-linear voltage output
wayne
Post by wayne »
How can I datalog a wideband with a non-linear voltage output?
I have an older FJO controller which doesn't allow switching to a 0-5v linear output.
mike93hatch
Post by mike93hatch »
get a wideband that does...thats how
wayne
Post by wayne »
Brilliant answer. I was looking for something more along the line of: use analog input 2. Will I be able to overlay/datalog this way?
mike93hatch wrote:get a wideband that does...thats how
yes you can use the analog inputs, but you will need to enter the full conversion table. You will not be able to use it for running in closed loop.
holset hatch
Post by holset hatch »
My wideband allows me to run a non-linear or linear signal to the ecu. if i use the linear do i have to input the voltage vs afr?
91 honda civic
turbo ls/vtec
You must always enter the voltage vs. afr or you will not have anything for the ecu to reference for conversion.
holset hatch
makes sense :oops: what is the difference between linear and non?
91 honda civic
turbo ls/vtec
linear means straight line
holset hatch
lol...in regards to the wideband signal? the signal is straight ok, so the voltage vs afr is easier to input?
91 honda civic
turbo ls/vtec
