NEW PLX SM-AFR
Posted: Wed Jan 02, 2008 5:11 pm
by DOHCAccord
Im trying to find out how to wire in the new wideband sensor from PLX into my laptop/ecu with the Hondata S300. The online tips and instructions only show the old PLX M100. Anyone have any ideas or thoughts or even the steps to set this up, nudge nudge to Hondata Admin.
Thanks in advance
Posted: Wed Jan 02, 2008 6:31 pm
by mike93hatch
and why wouldnt it be the exact same way you wire up a plx m300 ?
Posted: Wed Jan 02, 2008 7:02 pm
by DOHCAccord
im not saying its not, instead of online having it say options settings then wideband setup to just go in through closed loop in parameters.
but i want to confirm that the setup is the same since its new. make sense?
Posted: Wed Jan 02, 2008 7:21 pm
by mike93hatch
what setup are you exactly talking about ?
just the voltage/lambda conversion table?
ALL plx's new and old will be
voltage lambda
0.00 10.00
20.00 20.00
Posted: Wed Jan 02, 2008 7:24 pm
by DOHCAccord
no the wiring of it, i just dont want to follow the plx m100 wiring setup and fry something.
Posted: Wed Jan 02, 2008 7:45 pm
by mike93hatch
DOHCAccord wrote:no the wiring of it, i just dont want to follow the plx m100 wiring setup and fry something.
the wiring will be the same. take the wideband output wire from the plx unit and wire it to D10 on the ecu. cut d10.
Posted: Wed Jan 02, 2008 8:30 pm
by DOHCAccord
perfect. thank you, and double thank you mike, my name as well, im using your display with a few thing changed for my setup, rev limit etc. its great, good work and thanks again for all the help.
Got the SM-AFR too - one question one the 1k ohm resistor
Posted: Tue Jan 08, 2008 12:11 pm
by PianoMan
Piling on to this post, looking at the instructions, everything looks pretty clear to install, but I have one question:
The 1k ohm resistor: I have an old O2 adapter - just solder a 1k ohm resistor across the black wires (after removing the old sensor, of course), correct?
The instructions on the website:
"The adapter plug does two things. It puts a 1K resistor across the two black wires..."
Seems to imply the adapter itself provides the 1k ohm resistance, which I'm 99% sure is not the case.
Someone please confirm. TIA!
Posted: Tue Jan 08, 2008 12:39 pm
With the s300 you can just disable the heater, and do not need the resistor.
Posted: Wed Jan 09, 2008 10:00 am
by PianoMan
Spunkster wrote:With the s300 you can just diable the heater, and do not need the resistor.
Thx, Spunkster - I won't get the CEL? Or do I just disable the heater in SManager?
Posted: Wed Jan 09, 2008 10:45 am
Yes you disable it under parameters.
Posted: Thu Jan 10, 2008 3:40 pm
by PianoMan
Duh - I just figured out that's what you wrote in your first post. :oops:
Thanks again!
