JRSC at 11psi w/aftercooler Timing question...
wdsonny
Post by wdsonny »
Hello Hondata. It's Sonny again. The aftercooler is working great. I am seeing 10.5psi after the cooling core in the manifold and boost temps measured after the core never exceed 150F. Before the IAT was well over 200F. I have a question about timing. What would you run for timing in the high cam table at 50 degrees. I am at 22 in the 8psi column and 21 in the 12psi column. Is that too much. It doesn't knock, I had it up to 23/22 and it still didn't knock. What degree is too much and not making power?
honda crazzy
aftercooler?
Post by honda crazzy »
what aftercooler are you using?
which vehicle and jr kit?
i'm looking for a aftercooler for 989-555
fonz600
Post by fonz600 »
He has an RSX and makes his own aftercoolers. Checkout ClubRSX for details on it.
He ain't doing them anymore though.
