another s300 suggestion(sequential shift cut)
turbotypeR
Post by turbotypeR »
i was told that the k-pro has a sequential shift cut and was wondering if it could be added to the s300. it would need to accept a low or high voltage trigger like from a strain gauge and would need to retard timing for an adjustable time in ms. i think this would help some of us take it to the next level without having to switch over to motec or something. thanks!
92 civic Si
best et:9.43best mph:164
turbotypeR
any chance?
92 civic Si
ptredline
Post by ptredline »
please give us an answer
2 0 3
Post by 2 0 3 »
FWIW...
Im in for this too!!!
Ok, will add to the development list.
Post by 2 0 3 »
Thank you!!
693hp 2.0L 40R tuned with S300!!
10.37 @ 143 on kinda low boost =P
turbotypeR
Thanks! I love you guys! Hondata rules!
92 civic Si
HRED
Post by HRED »
Who know a sequential gearbox that fit on the B series ?
Should be interesting, I never found that in Europe.
Nicolas DARNIS
HRED Motorsport
turbotypeR
several people make a dog box. you can use a strain gauge to trigger the ecu to pull timing for a split second when you pull on the shifter and it will take enough load off of the engine to let it slip into gear under full throttle.
92 civic Si
Mr. Danieli
Post by Mr. Danieli »
turbotypeR wrote:several people make a dog box. you can use a strain gauge to trigger the ecu to pull timing for a split second when you pull on the shifter and it will take enough load off of the engine to let it slip into gear under full throttle.
Hi to everyone on the Hondata forum, new to the forum but long time Hondata user . I did not know that Hondata would even consider making an option like this on there new S300 software but if the did it would be great. I run a Libertys Gears gear set and I would love to be able to use it fullest, which this option would enable . I hope that Hondata really considers making this as soon as possible hopefully for the 2008 season ! Come on Hondata LOL !!!!
InlinePro.com
IPGParts.com
CompetitionClutch.com
Turbos Direct
9.70 @154mph Fall Nationals Etown
