Need H22 map for RC750's
I'm getting my car together but can't install the turbo yet (need exhaust) anyways just setup the computer (s300,p28) got it to run "okay" with the stock injectors but once I installed the RC 750s it won't run at all. I changed the injector size but since I'm not a tuner I have no idea how to change the fuel maps. I just would like to run the car with the 750s on with no turbo at the moment if possible. Plan on towing the car to get the the exhaust made but its still my daily driver.
I was able to get it to run half way decent. It has a slight bog of idle but it will do til I get ready to send it over for a down pipe and tune. Its still stock at the moment just running rich but better then lean. Reguarding the wide band. I plan on getting one in the near future. Running a narrow band at the moment. But the wide band is the number 3 on the list at the moment.
hardcorersxs
You won't know what your af ratio is with the narrowband. Invest in the wideband and then start tuning. Since you're not aware of tuning, put injectors back to stock and wait to get it tuned.Robs97'SH wrote:I was able to get it to run half way decent. It has a slight bog of idle but it will do til I get ready to send it over for a down pipe and tune. Its still stock at the moment just running rich but better then lean. Reguarding the wide band. I plan on getting one in the near future. Running a narrow band at the moment. But the wide band is the number 3 on the list at the moment.
