engine won't start
SiTurbo92
engine won't start
Post by SiTurbo92 »
I have a built Gsr motor but i'm breaking new motor in on stock parts..injectors,ecu,fuel rail and etc. I still using resistor box with 88-91 crx si but car won't fire. I did check for spark and nothing at all and swapped distributors from another motor and nothing. I was getting a check engine light and i was gettinga code 15, which i have no idea what it is. I would greatly appreciate it if somebody could help me out. One last thing i unplugged 3bar and now using stock map sensor.
AndyE
Post by AndyE »
Code 15 is Ignition Output Signal, which would jive with the symptoms you describe.
Do you have another ECU you can try?
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
SiTurbo92
Post by SiTurbo92 »
no but i'll try and fine one, thanks for the help
