will s100 let you pull CEL codes
Posted: Thu Dec 06, 2007 11:10 am
by hmglauj69
im having this problem of not being able to pull my CEL code. i've talked to 2 different hondata dealers and they said opposite things. ones says i should be able to pull codes myself with the jumper, and the other says i CANT and i need to use a s200/s300 to pull it with datalogging.
can any of you guys call bull on one or the other?
Posted: Thu Dec 06, 2007 1:13 pm
You should be able to under most conditions, but in this case you can't, so the next step is to have a Dealer use their s200 to datalog and see if they can find out what the error is from. You could have a bad ecu.
