aftermarket ignition coils
Posted: Sun Dec 02, 2007 12:47 am
by juniya79
Hello, I had a question in regards to running aftermarket ignition coils on my 07 civic si. I already had my ecm reflashed thru you guys, now i was just wondering if aftermarket ignition coils(okada racing coils) would be okay to run with the reflash. Thanks in advance for your help.
Posted: Mon Dec 03, 2007 9:38 am
We don't change any of the ECU hardware. If the coils work with the stock ECU, they will work with the reflash. However, be very careful when considering any change to the ignition system with regard to electrical interference.
Posted: Mon Dec 03, 2007 8:18 pm
by juniya79
could you please elobarate more on what may cause electrical interference and what negative results may occur if any interference is experienced..thanks!
Posted: Tue Dec 04, 2007 10:02 am
Honda has spent a lot of time and effort making sure that the ignition system works well and does not cause any interrence to any other component in the vehicle. There is little need to change anything other than the heat range of of the plugs at high boost - the Honda coil on plug ingition system works very well.
Posted: Tue Dec 04, 2007 11:02 pm
by juniya79
wow! that is some very interesting and helpful info. it'll help save me from spending 700+bucks too!!!thanks again!!
Posted: Sun Jun 15, 2008 10:28 am
by wolf74
take that 700 bucks and upgrade to a k-pro
your car will run much better
