Turbo b18c1 build need software help
Posted: Wed Nov 28, 2007 1:42 pm
by doccgsra
i have downloaded the smanager i am looking at the 3 d map is this for Wide open throttle for a preset fuel value? is there a option for a wideband o2 plugin? im lost
plans for this motor is a 60 trim and 15-18 lbs of boost.
I own a local shop and i want to know how this system works before i buy it
all the dealers i call will give me 0 help
Posted: Wed Nov 28, 2007 10:52 pm
by ITR 1102
Look at the 3d maps. There is one for low ignition, high ignition, low fuel, and high fuel. On one axis is RPM, on the other is load. So if you are on the low fuel map, you are actually seeing everything (partial throttle and full throttle)...
Do this, go to the low fuel table and select some cells. They will also be selected on the 3d graph. select other cells nearby and see how it changes the area that is highlighted on the map. That is the easiest way of getting used to the layout.
Try increasing the values a little to see how it raises up those portions on the graph, as well as increases the numbered value on the table.
Hope that helps.
Posted: Thu Nov 29, 2007 7:26 pm
by ben
I don't think you'll really get it until you've seen a live map trace. Watching the map trace will let you see what cells the ECU uses for different types of running conditions.
