looking 4 a hondata system?
stevend17
Post by stevend17 »
I HAVE A 2001 CIVIC EX IM TRYING TO CONTROL TIMING FUEL ETC. I HAVE A STOCK BOTTOM END A PORTED HEAD AND INTAKE WITH 3 ANGLE VALVE JOB IM LOOKING TO MAKE 200 HP ON MOTOR AND USE A 2 STAGE NITROUS KIT BUT HAVE NO WAY OF ADJUSTING 4 THE UPGRADES ANY HELP WOULD BE APRECIATED
STEVEN SPEYERS
ITR 1102
Post by ITR 1102 »
Hondata S100, S200, or S300...
Buy a chipped P28 ecu, Hondata S300, find yourself a tuner and you are good to go. I am not sure about the power expectations on the D series, so that I don't have any input on.
stevend17
thanx
Post by stevend17 »
ive done some talking locally and im told i cant use that system ive been told i have 2 use the k pro system and by a ecu that comes with some special timing gear to run the system there has to be some other way but like u no one knows much about this d series
STEVEN SPEYERS
ITR 1102
Post by ITR 1102 »
K-Pro is for K series engines... You have D. The S100,200,300 work with D, B, H, and as far as I know, F series (accord) motors.
All you need is an OBD1 chippable ecu (P28), and OBD2b to OBD1 conversion harness, and one of the Hondata systems stated above.
I can help you see exactly what you can use and need....
The above information is all incorrect.
The 2001-2005 Civic has a D17 which we offer teh K-Pro for. It uses a CUstom Adjustable Cam gear that we sell. THe s100 -s300 will not work with this vehicle at all.
http://www.hondata.com/wizard/wiz_civic_01.html
