B16b Hondata S200 CEL ON
japerformance
Post by japerformance »
Hello Peeps,
having a small problem. i have a EK9 fitted with the s200 the cel light is on all the time, i have replaced the ecu with a p28 , i have changed out the s200 with my own dealer one i have changed the roms etc nothing seems to cure the cel. in hondalogger no error codes are coming up any ideas , has anyone had this happen to them before.
regards
Do you have the knock sensor disabled? Have you tried datalogging to see what the error code says?
japerformance
yes have disabled the knock sensor and have also ran hondalogger with no error codes showing am stumped
ek9lee
Post by ek9lee »
Hello Simon I just registered here to see if I could find out anything but it seems your 1 step ahead of me :lol:
japerformance
yep as usual
Is the light on the interface box flashing or solid? Based on the fact that you have changed everything ecu and Hondata related and the problem still exists, it sounds like a wiring problem or problem with the cluster. Does the light go out at all or is it on whenever the key is on?
ek9lee
Post by ek9lee »
The light on the interface box is solid. The light goes out when the ignition is at number 2 then its constant when car is started and running.
I'm asking about the Check engine light on the cluster
ek9lee
Post by ek9lee »
Yeah sorry thats what I was on about in the second sentence of that post.
ITR 1102
Post by ITR 1102 »
I had a similar issue once... Turned out that the chip was not burned correctly. Do you get the same results when using the ostrich?
Datalog and check to see what you have the shiftlight set to.
ek9lee
Post by ek9lee »
The shift light wasn't installed
not having a separate shiftlight installed has nothing to do with checking the settings I have suggested. Please check to see what you have the shiftlight set to. If it has been set below what your car idles at, the CEL will always be illuminated.
marlborocars
Post by marlborocars »
Just tap a wire between D6 and A4. The B16B don't have the vtec pressure switch.
mike93hatch
Post by mike93hatch »
marlborocars wrote:Just tap a wire between D6 and A4. The B16B don't have the vtec pressure switch.
why would you do that when you can just disable by checking a box in hondata?
