Launch control..
Posted: Mon Jun 16, 2003 2:33 pm
by twidge
Hey, I got a quick question here. With the launch control on the S200 system, will it act like an MSD 2-step and build boost off the line, or does it just maintain the RPM's?
Posted: Tue Jun 17, 2003 1:53 pm
by AndyE
The launch control system simply lowers the rev limiter (via fuel cut) when the clutch is depressed. So for example, with launch control set to 4000 rpm, when the clutch is pressed in, the rev limiter would max out at 4000 rpm. When you drop (release) the clutch, the rev limiter returns to whatever max value you have set.
No fancy boost management or anything of that sort.
