Launch control..
Launch control..
Hey, I got a quick question here. With the launch control on the S200 system, will it act like an MSD 2-step and build boost off the line, or does it just maintain the RPM's?
The launch control system simply lowers the rev limiter (via fuel cut) when the clutch is depressed. So for example, with launch control set to 4000 rpm, when the clutch is pressed in, the rev limiter would max out at 4000 rpm. When you drop (release) the clutch, the rev limiter returns to whatever max value you have set.
No fancy boost management or anything of that sort.
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
