PLX m300 with Kpro
Posted: Wed Nov 14, 2007 11:40 am
by blueshark123
Im going to be using my PLX m300 for datalogging with Kpro. I am aware that I must connect the white wire from the controller to the ELD pin on the ecu. What Im not sure of is what settings need to be set on Kpro to get this to work. The settings would be much appreciated. Thanks for your help in advance.
Posted: Wed Nov 14, 2007 11:45 am
by blueshark123
Also just to be sure. The ELD pin is E15 on the ecu correct?
Posted: Wed Nov 14, 2007 12:53 pm
In Kmanager, go to Help, Contents, and in the search field, type wideband settings and let it search. Under Settings look at the Wideband Lambda Input. E15 is the ELD input.
Posted: Wed Nov 14, 2007 1:00 pm
by blueshark123
Spunkster wrote:In Kmanager, go to Help, Contents, and in the search field, type wideband settings and let it search. Under Settings look at the Wideband Lambda Input. E15 is the ELD input.
Yes I am aware of this. Is this the only thing I have to do? Do I not need to change the voltage offset? Also if I remove my primary would I be able to run closed loop using the secondary? I am currently running open loop and have been doing so since I got tuned. My primary is toast and is throwing a code. From my reading it seems that only the PRA ecu can use the secondary for closed loop and simply disabling P0134 will eliminate the error code. correct? I just want to be sure before I do it this weekend. Thanks for the help!
