s300 not communicating
my car was dyno'd and raced, i never set the launch control due to vss not working. i fixed vss and want to set the launch rpm, but i can't get the ecu to communicate with my laptop. this is the first time i am trying to use my ibm notebook to set anything. i went through the driver install and the s300 shows that my laptop is online when connected to ecu. any ideas?
saying that the "screen" doesn't "do anything" is rather vague. are you saying that your laptop screen isn't turning on? if so, i recommend charging the battery.
seriously though, describe your problem a little better and you'll get better help.
what version of smanager do you have?
when you hook up the usb cord, does the laptop recognize that the s300 is connected?
in smanager, if you click "online" in the menu at the top, are upload and download available or greyed out?
are you opening a calibration file stored on the laptop or downloading the calibration from the s300 unit?
while the car is running, when you click the "record datalog" button (the red circle) does it open a graph showing your rpms/afr/map reading?
mike93hatch
- Contact:
