Lambda problem...
Stuart
Lambda problem...
Post by Stuart »
OK,
as the data output is not avaliable on PRA ECU's, I have changed it out for a PRD (all I could find in a hurry!).
re-wired the engine loom etc for the different primary lambda sensor, etc etc.
engine runs just fine, but the lambda display is perminently 0
now, before you say it's not wored right or it's faulty, it's working and is running closed loop just fine??
I have attached a datalog, it's from one of the std maps for an RSX
Looks ok to me. Make sure KManager is updated, then check in Settings that the wideband is set to the built in wideband.
Stuart
Post by Stuart »
thanks!
it was in settings (set to ELD??)
looks like it got changed in an version update?
Stuart
