Cold Engine Rev Limiter?
Posted: Sun Oct 21, 2007 6:03 am
by tryfe
I'm only thinking of this because the other day my fiance flogged my car as soon as she fired it up & backed out of the driveway..
How about implementing an alternate Rev Limiter when the engine is still cold? For example, be able to set the Rev Limiter to 4k when the ECT is below normal operation temperature...say below 180 degrees. Can this be done?
Posted: Sun Oct 21, 2007 3:14 pm
by petah
better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
Posted: Sun Oct 21, 2007 3:30 pm
by tryfe
petah wrote:better way to protect your car is dump your fiance and find a girl that will treat your car the way you would.
No.
Posted: Mon Oct 22, 2007 10:31 am
Prameters, Protection. Set it to 5 inches of vacuum.
Posted: Mon Oct 22, 2007 11:07 am
by tnhatch02
lmao. all you should have to do and say is be careful. that or never let her drive ur car again.
Posted: Tue Oct 23, 2007 2:42 am
by tryfe
Spunkster wrote:Prameters, Protection. Set it to 5 inches of vacuum.
Thank you.
Posted: Tue Oct 23, 2007 11:31 am
by JJA12
By doing so, what will be the limited rpm?
Posted: Tue Oct 23, 2007 11:50 am
by petah
JJA12 wrote:Spunkster wrote:Prameters, Protection. Set it to 5 inches of vacuum.
until the coolant temp is over the specified limit
Posted: Sat Nov 10, 2007 8:43 am
by tryfe
I've observed that my car will not go WOT; which is exactly what I wanted until the car warmed up.
