Looking for documentation & questions
Posted: Tue Oct 16, 2007 12:25 am
There are some detailed documentation I am looking for which I did not find.
For example, I am looking for expected engine behavior on the overrun fuel cutoff - is there some description on this? Is the RPM values changeable in the software? How does the map work? How does the overrun cuttoff work beyond the rpms in the table?
What does selecting gear ratios do? How does this affect the tune?
Why is the overrun fuel cutoff option not available for the ep calibrations?
How does the "disable overrun cuttoff delay" work - what is the expected behavior? What is the default delay? Does this work alongside the overrun table in the advance tab? Does this have higher priority?
Can the knock threshold map be given & defined by the user? Is knock dependent on temperature? If so, can temperature be used to control ignition?
Can the idle control also be given to the user? I see the slider - what does it actually do? What does each point on the slider correlate to?
When will all sensors be added to the display tab under settings as well as the display window? Can you enable a custom "sensor" or function so that a user can define his own "sensor" using arithmetic with sensor data to obtain a realtime postprocessed data? Can we disable some sensors which we do not want to see in the sensors window?
I would like to be able to use lambda overlay to automatically apply changes to the map files. What are the concerns with enabling the user to do this? Can you give the user the ability to control the algorythm for the lambda overlay or allow knobs for the user to play with?
I have asked some of these questions before and have not seen any progress. Can someone help?
fvang
fvang
