car wont stay on , was running fine
Posted: Sat Oct 13, 2007 12:09 pm
Im on hondata s300, was driving the car for 2 days , then it stated just reading from the 0 column while datalogging and would turn off from being rich.
I have tryed a motorola map, then an aem 3.5map, and even tryed to turn it on with a oem map sensor, all the same outcome.
I have also tryed switching to my old uberdata ecu and the same.
with a volt meter I get 5.00v from the power to map using the map ground for ground, and the signal read at the ecu with key on is 1.67v from the aem 3.5
what could be wrong???
there is fuel and spark and all of that.
and if I try to keep it on by just holding the gas pedal floored it is bearly on and threw a tps code, that it never threw before
Ill get tps readings right now
