S300 freezing up with MSD Ignition
thudreem
Post by thudreem »
http://www.honda-tech.com/zerothread?id=2122381
Were are having this problem, can you guys help us out?
The problem is not the s300. OEMs make their ignition systmes to much higher quality standards and must keep electrical noise/interference to a minimum. The problem is that aftermarket ignition systems are not made to these high standards and generate a lot of interference.
thudreem
Post by thudreem »
Is there something I can put inline from the alternator or some wire that leads from the ignition to the ECU that will reduce the interference?
SFWD 1934
Post by SFWD 1934 »
Sean,
I posted on the link you left on HT.
Jason
9.86 @ 152
Not really, the interference is picked up through the other wires and the chassis.
