Stage 2 boost question
Jaker
Post by Jaker »
If I have an old stage 2 with datalogging, but no boost capability, and I have the Version 3 Rom Editor (bought it with a new S200), would I be able to run boost with the Stage 2, up to 11 PSI?
AndyE
Post by AndyE »
You can create ROM images for v2.5 (i.e. stage 2/3/4) systems using ROMEditor. However, I believe the interface box determines the boost option in the v2.5 systems - so I don't believe you can convert a stage 2 to a stage 2b just by burning a different ROM. (But you could always try it and see...)
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
