06 SI
Posted: Wed Oct 03, 2007 8:15 pm
by htec17
I would like to know if the tsx throttle body can be used with the 06 SI with the comptech charger? and can I run the tsx bottom end with the reflash I have for it now?
Posted: Thu Oct 04, 2007 9:30 am
I don't know about the throttle body, but changing to a 2.4 block will not be compatible.
Posted: Mon Oct 08, 2007 7:39 pm
by htec17
would you use the hondata img or the comptech one supplied with the charger?
Posted: Tue Oct 09, 2007 9:38 am
It is completely up to you.
Posted: Tue Oct 09, 2007 7:41 pm
by htec17
Would it be worth using the 05-06 rsx type s cams being they are the type r cams and the stock ex cam on the si is the same as the 04 type s ex cam? how much of a diffrence will i get with the 64mm throttle body.
