Hello.
Hard to find any information about it, becouse not many poeples using it.
We don`t know why Seq shift cut not isn`t work.
ECU PRA from Euro CTR .
We used all input for test (E16,E22,E29), and nothing.
In logs input signal arrived to ECU (E22BKSW) from the switch installed on Seq tramission, but ECU not cut...
Kmanager 1.2.2.8
Logs: www.hondata.pl/seq1.kdl
Cal: www.hondata.pl/seq2.kal
Thanks for any advice.
Problem Seq Shift Cut. Need help.
www.Ecu-Performance.com.pl
Euro CTR Boost - 1/4 12.066s ET
thank you for information.
When new release should be available? Ofcourse approximate date.
marccharlton
Sequential Shift Engine Cut
I have tried this feature several times with differnet inputs / timings but have failed to get it working. Last time I tried it caused engine cuts at high revs with out touching the gear lever and even disconnected. It is crutial to our racing programme and must achieve flat shifting one way or another. I read on the forum others have also failed. Has anyone succeeded to get it to work? If so how did they get it to work? What is the software change that was(?) introduced in Oct? :?:Hondata wrote:Oct 26th at the latest.
