IAT, INTAKE AIR TEMP QUESTION?
Posted: Thu Sep 27, 2007 5:59 pm
by boricua
Can i clear the code using TDC? how important is that little white sensor on the intake?
Posted: Fri Sep 28, 2007 10:15 am
The IAT sensor is very impportant. I don't know what you mean about the TDC sensor?
Posted: Fri Sep 28, 2007 12:15 pm
by boricua
Ok you know if i can erase the code by using the tdc command on hondata?
Posted: Fri Sep 28, 2007 2:51 pm
I do not know what you mean by the TDC command?
Posted: Sat Sep 29, 2007 7:08 pm
by boricua
Ok i replaced the AIT sensor and now it's reading 123f, but the check engine light is still on, when i clear it Using DTC on the s300 manager the check engine ligts still stays on and on the s300 manager error codes it clears then comes back on.
I'm a noob to this and it's driving me F'N crazy, i tried resetting the ecu by pulling the back up ecu fuse and now it runs like crap, can someone please help.
If their is a tuner in the jacksonville Florida area please let me know, i don't mine paying.
Posted: Mon Oct 01, 2007 9:38 am
What is the exact error code you are receiving?
http://www.hondata.com/dealers.html
Posted: Tue Oct 02, 2007 11:02 am
by boricua
ok i got it fixed, it was a code 10 air intake temp sensor, but after resetting the ecu does it clear my program i already had set?
Posted: Tue Oct 02, 2007 2:14 pm
resetting the ecu does not do anything to the program.
