check engine in cut off
Paulo
Post by Paulo »
Hello, installed a S300 in a P30 ECU Civic VTI engine B16A2 93 turbo.
In Cut off it ties the light of the check engine.
It doesn't generate DTC error code.
Because this happens?
How do I do to solve?
Thank's
Paulo
You'll have to describe the probelm better and include datalogs and calibraitons showing the problem.
Paulo
Post by Paulo »
Hello, here is the log file and the calibration
Paulo
You must describe the problem better so we know what we are looking for.
Paulo
Post by Paulo »
Ok, after to accelerate and to fill the turbo leave the car to walk with any march clamped without accelerating. In this condition the motor cuts and it generates the DTC code.
Thank's
Paulo
I'm sorry, but your description of the problem does not make any sense.
None of the datalogs show any error codes.
Paulo
Post by Paulo »
I find strange, when I made the datalog it generated an DTC error.
I will do again.
Doesn't really have sense the problem. I don't also understand because it generates DTC.
Regards
Paulo
Paulo
Post by Paulo »
Hello, did more two dattaloger.
See if you get to see the error.
Regards
Paulo
the first datalog shows a map sensor error. I would suggest following the factory service manual for troubleshooting that error.
