s200 connection problem
ej2_junky
Post by ej2_junky »
hi,
i have the following problem with my S200 (serial:0486)
i connect it to ECU with the serial cabel and when i start Hondalogger and klick connect, its works for 1,2sec an than came a few time the massage,dataloggin not available. and now it cames ever connection error. so i cant datalogg and also cant read the ecu information.
My Ecu is socketd correctly, i have a crom chip on it and the engine still run with it. (no engine controll lamp and so on)
so wher is the problem???
works datalogg not on an stocke ecu?
or must i have an eprom witch is burnd with romeditor?
btw The interface box LED is flashing slowly,
thx and regards
from germany
You are either not using a Hondata ROM image, or you have not burned the correct file. You will need to post more information including the calibration and what version of software you are using.
ej2_junky
Post by ej2_junky »
Spunkster wrote:You are either not using a Hondata ROM image, or you have not burned the correct file. You will need to post more information including the calibration and what version of software you are using.
then i think the problem is the chip, burned with crom, its only a base chip.
the chip was only to test if the ecu socketd correctly,
now i will order a rom that burnd with hondata software und test agin.
thx as far as
i will report to, when it still dont work.
ej2_junky
Post by ej2_junky »
so now i get a chip that is burn with romeditor and the led flashing no more,
i can connect with romeditor,
but datalogin dosen?t work, in the ecu information is only boost enable??
has my s200 datalogin not available??
Serial is s200-0486
You don't have datalogging. You have boost only.
ej2_junky
Post by ej2_junky »
I thought as much.
can you tell me how i can aktivate the dataloggin?
btw weher i muss pay the 100$ for the 3 step rev limiter and dataloggin?
here in germany are no dealers for hondata.
thx
ej2_junky
Post by ej2_junky »
hmm thats simple, now i need a dealer or where i can buy the codes?
