wideband off in higher RPMS?
Posted: Wed Sep 19, 2007 11:27 am
by DCxMagus420
I'm running a H22a4 with a P28 hondata ECU with a M series PLX wideband.
I notice that in the higher RPM's my gauge will read 12.6-12.8 but it gets datalogged at 13.1
but in the lower RPMs everything matches up fine?
the wideband is ground at the ECU jumper harness and I have the capitors from PLX installed as stated in the instrutions.
I have the wideband set up to the ELD D10 pin, with the wire cut, and am using the stock narrowband for closed loop
Posted: Wed Sep 19, 2007 12:34 pm
Where are you getting power?
I would recommend using the switched 12V source at the under dash fusebox, and for the ground use a good solid chassis ground.
Posted: Wed Sep 19, 2007 12:44 pm
by DCxMagus420
everything is wired at the jumper harness like it said it should be at the PLX instructions.
Posted: Wed Sep 19, 2007 1:38 pm
We do not recommend getting power or ground from the ecu harness. Please follow the intructions on our website.
Posted: Thu Sep 20, 2007 2:34 pm
by DCxMagus420
Switched the ground to a chassis ground near the OBD2 port, adjusted the table as suggested by PLX. Everything matches up fine in all RPMs now.
Thanks spunkster for the quick accurate response =)
