Base calibration help needed, d-series dohc turbo hybrid
doo0T!doo0T!
Post by doo0T!doo0T! »
Does anyone here have a base map calibration I can use to start off with?
The calibrations i could probably start with are;
P74 B18b non-vtec
D16 supercharged with 440cc's
Greddy B16a?
But I was hoping someone else here has used an S300 to tune their non-vtec d-series turbo and wouldn't mind sharing the file.
The thing is my engine is pretty much a one-off, it's a dohc ZC head modified to fit a SOHC D-series block with PM6 pistons which as far as i know has never been done before successfully.
It's 8.3:1 compression and i am running 560cc injectors and a T25 turbo.
Because it's non-vtec I only need the low cam maps but with the 560cc injectors and no ICAV it's going to be a hard task writing a base calibration from scratch, especially as I'm new to this.
Can someone please lend me a file to start off with?
Regards,
Mike
-JDM EF7-Si CRX ZC/d16a6 hybrid turbo
-JDM EG5-Si hatch with H22a swap
-JDM EJ7 coupe, evo H2B with H22a-EuroR
