can't get plx wideband to work on s300
Posted: Sat Sep 15, 2007 7:25 am
by turbotypeR
i have my dm-5 sm-afr hooked up and the gauge works, but i can't get it to read right on the s300. It is reading in the .7's and .8's when the car is idleing around 11.0.in the settings, i have the plx mseries selected.air/fuel selected. ihave hooked it to d10 and d14 and of course selected the correct source for each. what am i missing?
Posted: Sat Sep 15, 2007 10:11 am
by turbotypeR
here is my calibration and datalog.also, notice on my dtalog that my ect locked up at 236. it was only about 180-190.could the sensor be bad?
Posted: Mon Sep 17, 2007 9:56 am
Nothing locked up, your car is overheating. It got up to 242.4 degrees by the end of the datalog. Double click on the AF in the sensor window and make sure you have it set to read AF and not Lambda.
Posted: Mon Sep 17, 2007 10:05 am
by turbotypeR
i found that the ect sensor was bad. i put another one in out of a car i had out back and it worked fine.i put mine in the other car to plug the hole and as soon as i started threading it in, it brokein half. i have made sure air/fuel was selected several times. it idles around .85 when the gauge reads 11.0 or so and if you leave the key on, when the gauge goes lean it reads about 1.36. sounds like it is reading lambda to me
Posted: Mon Sep 17, 2007 12:20 pm
THere are 2 places to specify LAmbda or AF. You must do it in both... Settings and Sensor list.
Posted: Mon Sep 17, 2007 12:39 pm
by turbotypeR
Ok. I'll have to check. I know I selected it in settings but i need to check sensors when I get home.
Posted: Mon Sep 17, 2007 5:20 pm
by turbotypeR
that was it. kinda hard to calibrate though
