can't get plx wideband to work on s300
turbotypeR
i have my dm-5 sm-afr hooked up and the gauge works, but i can't get it to read right on the s300. It is reading in the .7's and .8's when the car is idleing around 11.0.in the settings, i have the plx mseries selected.air/fuel selected. ihave hooked it to d10 and d14 and of course selected the correct source for each. what am i missing?
92 civic Si
best et:9.43best mph:164
turbotypeR
here is my calibration and datalog.also, notice on my dtalog that my ect locked up at 236. it was only about 180-190.could the sensor be bad?
92 civic Si
turbotypeR
i found that the ect sensor was bad. i put another one in out of a car i had out back and it worked fine.i put mine in the other car to plug the hole and as soon as i started threading it in, it brokein half. i have made sure air/fuel was selected several times. it idles around .85 when the gauge reads 11.0 or so and if you leave the key on, when the gauge goes lean it reads about 1.36. sounds like it is reading lambda to me
92 civic Si
turbotypeR
turbotypeR
