Which wideband?
Posted: Thu Sep 13, 2007 11:54 am
by Potterbilt
Which wideband do i use? And do i only need the sensor or do i have to buy the complete 200-400 kits? I have found the bosch lsu 5 wire for about $60 among others. Can i just install that according to the instructions, and use the s300 to street tune or do i have to buy one of the whole plx , innovate, aem kits? And if I do which kit is the best? In other words what is the cheapest way to be able to tune my A/F acurately?
Posted: Thu Sep 13, 2007 1:13 pm
You cannot use a sensor alone. We recommend the PLX packages.
Posted: Thu Sep 13, 2007 3:14 pm
by Potterbilt
Okay is the PLX DM-5 SM=AFR combo a good choice? I like the guage ... Also why would you daisy chain these unit, why would there be a need for more than one?
Posted: Thu Sep 13, 2007 3:57 pm
Any PLX system will work, the choice is up to you.
Posted: Thu Sep 13, 2007 4:29 pm
by Potterbilt
I was reading up on the auto tune function. Does it only work in open loop?
Posted: Thu Sep 13, 2007 4:56 pm
That is the only time it should be used. We find that the autotune fuction will only get you a rough map to start with, and then you must smooth it out from there.
Posted: Fri Sep 14, 2007 8:25 am
by ibiot
I have an innovate LC1 with moates.net O-meter package and I love it. All the wiring is done at the ECU and only took like an hour to wire. The o-meter mounts really easy anywhere on the dash. I have the output going to the ELD input on the ECU and s300 autotunes with it. Also, im using the narrowband output, so no need for the factory o2. Heres a link:
http://www.moates.net/product_info.php? ... cts_id=134
heres mine:
Posted: Sat Oct 13, 2007 4:07 am
by Potterbilt
Okay I have the plx dm-5 now. I am ready to install but I have a question. My car is a 96 civic ex, with a b18c1, and an OBD1 ecu(obviously). I have two O2 sensors one where the cat used to be, and one about a foot and a half closer to the motor. Is there a way to use the one closer to the motor and keep the one where the cat was, and would that be benificial at all? If so how should I connect it? Thanks for the help.
Posted: Mon Oct 15, 2007 9:40 am
OBD1 only uses the primary o2 sensor. THe one is the cat is not connected to anything.
